Check Engine Light on, need help with codes
Old Mar 9, 2015 | 07:32 PM
Filters are generally replaced on an as needed basis. Rule of thumb with the PCV valve is, if it rattles, it's good, just need to make sure it has good, strong manifold vacuum to it at idle. Upstream oxygen sensors are typically good for 100K miles. More than that, they can COST you money in fuel mileage. AC Delco and Denso oxygen sensor response times are the fastest, (which is good). Denso is slightly faster than AC Delco and less expensive. AC Delco lasts a little longer....it's a toss up.
Old Mar 11, 2015 | 06:54 AM
tallbump's Avatar
tallbump is on a distinguished road
Got all the parts ordered. They are supposed to arrive Saturday.
Old Mar 19, 2015 | 06:55 AM
tallbump's Avatar
Did the plugs and wires on Monday. Man that driver's middle (#3?) was a PITA.
But it's running WAAAAY better now. Pretty sure that plug was the factory original.
It was a Delco...all the others were Auto LItes
Old Mar 19, 2015 | 12:19 PM
LesMyer's Avatar
I find it easier to simply disconnect the steering shaft from the box (one bolt)and move it for access to #3. Then you are not so likely to break the plug porcelain when putting it in.
mfd70
Aug 15, 2020 04:46 AM
stce33
Jan 19, 2011 02:44 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
