check gauge light comes on
New to this forum. I just bought a 99 blazer ls from a private seller, 85,000 miles. my only concern is that I did not realize when I bought it is the check gauges message that comes on when I turn it on. I did a search and it comes down to either a problem with the pressure in the gas tank or the fuel pump running weak. If anyone here can help on what the problem might be please help!!! I hope it is nothing serious, specially after dropping all my savings on this vehicle. Thanks for the help in advance!
That has nothing to do with the fuel pump/tank. It is a message telling you that one of the critical engine functions is out of spec. It could be that the engine temp is high or the oil pressure is low, or something else. It is a warning to get your attention on the gauge cluster so you can see what is wrong.
But if it is only when you start the truck and it goes out, that is normal.
Sounds like it is normal them, thanks for the help. My other concern now is the ABS light that seems to come on unexpectedly every now and then. Any guess as to what that might indicate?. On a nicer note I got the engine steamed cleaned yesterday, I will post photos later. Huge difference. Thanks for the help.
bulldogauto
Jun 28, 2021 10:41 AM
scott_wheels
Jan 26, 2010 05:49 PM
chrisjanicki01
Sep 4, 2009 05:34 AM
Kingman1901
17
Nov 9, 2008 04:44 PM
