chugging
The best I can describe it is a chugging kind of an unbalanced tire. I can feel it in the steering and in the seat, its not terrible but is noticable. Tires seem fine and pressures are right, tranny fluid looks good and smeels fine. I dont notice any rpm changes and the obd2 doesnt show a miss. What could be causing this vibration?
Ok checked brake they seem good on all four, I pulled out the torque wrench and double checked all wheels the left rear had 3 lugs that were slightly under spec. In a quick test drive it seemed fine. I will repost if it seems to still be there.
OK update it is still doing it, it does seem like an unbalanced tire, but it seems to do it between 32-45F which seems odd, if its hotter it wont do it, and if its colder it doesnt seem to. If it is an unbalanced tire is there a way to narrow it down so I dont have to rebalance them all?
Try puttin on a buddie's wheels and tires f(if you have one with a blazer) and drive it around, see if the problem persist. That'll let you know if it's your tires and/or rims or if it is something on the truck that is messed up.
schnarr
Aug 25, 2008 11:37 AM
