clicking while accelerating! 4wd trouble to - just got new fornt end parts!
Old Nov 19, 2010 | 12:29 PM
You said that the noise is coming from the back. Is that the case or does it change when you put it into 4wd?
Old Nov 19, 2010 | 12:49 PM
dj00140's Avatar
dj00140 is on a distinguished road
I cant really tell to be honest, seems middle. now when I switch to 4wd it seems like the bang-bang-bang avery 1/4-1/2 turn of the wheel (unless im going straight) seems to be in back...
But can the u-joints cause that in 4wd? im leaning toward t-case, but the light rattle/vibration seems weird nut doesnt sound bad like the loud *** ticking thanks swarikk
Old Nov 19, 2010 | 02:15 PM
It could be a combination of problems like I sort of eluded to earlier. If you are hearing the problem directly under you, then it is possible that the joints right near the transfer case are bad on both the front and rear driveshafts.
Old Nov 19, 2010 | 02:44 PM
dj00140's Avatar
And to test the u-joints what do I do?
And is there a way to test the t-case, I mean it goes into fwd it juts clicks bad when I turn the wheel at all.
Old Nov 19, 2010 | 02:48 PM
I would pull the driveshafts out and literally move the joints to feel how well they move. It should be a nice, smooth movement.
As far as the t-case goes... I'd have to think on that for a bit... I'm going to be pretty inaccessible for the next few days though.
Old Nov 19, 2010 | 11:10 PM
dj00140's Avatar
also it vibrates at 55-65 when i press on the gas looking into the vibrating thing i guess that is common, I need new tires badly,
Now they said to test the transfer case, put in 4hi and grab the driveshaft and see if it turns it shouldnt, now mine turns like a half inch and when i pull it there is very very slight give, now is this bad u joints or should there be very slight give like this in the driveshaft under the drivers floorboard? Thanks you guys
Old Nov 25, 2010 | 10:10 PM
dj00140's Avatar
Turns out its the transfer case, I will update after I replace it with a used one this weekend!
Old Nov 29, 2010 | 10:06 PM
dj00140's Avatar
Fixed it, but now the 4x4 no worky lol
jmann0526
Sep 24, 2014 07:31 PM
bassson
Sep 4, 2013 05:33 PM
zcat23
Sep 29, 2010 10:30 AM
ldkronos
May 3, 2010 11:36 AM
lemon blazer
Aug 6, 2007 05:32 PM
