Clutch fan removal
Old May 10, 2014 | 02:46 PM
faulknej's Avatar
faulknej is on a distinguished road
Default Clutch fan removal
The manual says to "hold the water pump pulley and remove the nut attaching the fan to the water pump." Just exactly how are you supposed to do this? I cranked on the tensioner and the belt just kept on slipping while I tried to turn the nut. Any suggestions?
Old May 10, 2014 | 03:06 PM
rockp2's Avatar
Borrow the correct tools from an auto parts store. Many loan them out.
Old May 10, 2014 | 03:47 PM
faulknej's Avatar
The only tools the auto parts store had was to turn the nut. How do I hold the pulley?
Old May 10, 2014 | 04:57 PM
newguy's Avatar
use a long screwdriver or prybar between the bolts while smacking the wrench with a hammer. worked for me
Old May 13, 2014 | 12:50 PM
JasonGoneFishing's Avatar
JasonGoneFishing is on a distinguished road
We simply use a big wrench, a BIG wrench and used a rubber hammer, came right off. We just changed the water pump..
Old May 13, 2014 | 04:47 PM
rexazz2's Avatar
if you partially back out 2 of the water pump pulley bolts you should be able to hold with a screwdriver or even the flat bar from a belt tensioner tool
Old May 13, 2014 | 05:50 PM
Those methods work great. If you're **** on using the tool, here it is: OEM/2 pcs. fan clutch wrench set (27018) | Fan Clutch Wrench | AutoZone.com_
The nut on the clutch is 36mm. An open end wrench works much better than the POS in the tool kit.
Old May 13, 2014 | 06:48 PM
AJBert's Avatar
I pulled the belt off and threw a strap wrench on the water pump pulley. Worked good for me.
Old May 13, 2014 | 08:35 PM
rexmburns's Avatar
Super Moderator
I used this
About 3 seconds of pulling the trigger and she was loose!
gitch93
Jul 23, 2013 08:06 AM
cheesequaker
Apr 25, 2012 01:44 PM
85kulan
Oct 4, 2011 09:51 AM
MintyMadness
Jul 13, 2011 12:37 AM
ronkrolock
Aug 19, 2009 06:50 PM
