Code P0171 and Leaking underneath
Old Oct 15, 2012 | 02:36 PM
GMC_Jimmy_13's Avatar
GMC_Jimmy_13 is on a distinguished road
Ok wasn't leaking out of the fuel test port. But I had to cave and take it to a mechanic cause I'm out of time (starting new job). He just called and said its the o2 sensor that is affecting gas mileage and making it run rough? Does that sound right? I know that's not the leaking part tho he is looking for that as we speak.
If it is the o2 sensor how hard are they to replace if you never done one before? Need any special tools?
Old Oct 15, 2012 | 03:14 PM
spittybays
Guest
Posts: n/a
On a 96 it could be tough if it has not been done before. Need to hit it with a torch and braker bar. Monkey/pipe wrench or expensive tool. Cheap ones they give you at zone are crap. Let him do it while he has it and good luck with your new job!
Old Oct 15, 2012 | 03:15 PM
A dead O2 sensor can cause poor mileage and rough running. The PCM is applying maximum pulse width, (full rich) to all 3 injectors on the driver side. Not difficult at all to replace. Drive it and get it hot, un plug & unscrew it. Some of the auto parts stores rent oxygen sensor sockets, if you need it.
Old Oct 15, 2012 | 05:11 PM
do you guys think 175 is expensive? how much is a o2 sensor from a parts store
Old Oct 15, 2012 | 05:42 PM
The sensor is under $100 and less than 1/2 hour labor, but don't forget his diagnosis time.
Old Oct 16, 2012 | 01:01 AM
the guy cant explain or find the leaking fuel though which isn't much help....uugggggggghhh
Old Oct 16, 2012 | 09:24 PM
Did they do a leakdown test?
What's with the spare tire carrier, tail pipe, and steering wheel in your signature image? It's not RHD, must be a mirror image
Old Oct 16, 2012 | 10:37 PM
ok now they told me that is a leaking fuel injector thats causing bad mpg. How hard is that to do on your own?
- and yeah its a mirror image haha
Old Oct 16, 2012 | 10:43 PM
Not difficult, and no special tools involved, but the injector assembly is ~$200 on Amazon. Make sure you get the upgraded injector assembly, Delphi # FJ10565.
Old Oct 20, 2012 | 04:11 AM
Ok got it back from the shop and 600 bucks later i got ONE fuel injector line fixed...I know i woulda dont that myself but i ran out of time. But anyways i picked up an o2 sensor and going to fix that tomorrow. here goes nothing
05BlackJimmy
Nov 30, 2012 05:35 PM
crater
Nov 11, 2011 12:03 PM
LJStone
Jul 29, 2011 09:33 PM
waterfowlhunting
Apr 19, 2010 09:14 AM
blazervortec
May 11, 2005 06:06 PM
