Code reader will not connect to computer it does light up and try to scan
Old May 27, 2023 | 09:22 PM
GeorgeLG's Avatar
I think so, i dont think that any of those wires are twisted or shielded.
George
Old May 28, 2023 | 12:22 AM
GeorgeLG's Avatar
Did this scanner communicate with this engine computer when you first got the truck? Do you have another scanner you can try?
George
Old May 28, 2023 | 07:36 PM
Scubacarib's Avatar
Scubacarib is on a distinguished road
i never tride to scan it came on a tow truck it did work on my 97 gmc. Sonoma what wire and plug would it be at the computer i will get a list of probs on dash
Old May 28, 2023 | 07:46 PM
GeorgeLG's Avatar
The class 2 data line from the engine computer is dk grn on C4/P11.
George
Old May 29, 2023 | 04:05 PM
Scubacarib's Avatar
I jumped the wire from just behind the computer dk green to purple on splice pack (that would be like jumping purple to dk green) and no communication the car starts (although it kicks back and then will restart just fine ) and seams to run ok short drive and it shifted fine the bat light is on but gage shows about 12 and jumps to 14 when started also abs security air bag and low fuel light is on i am thinking computer but don't know could a computer cause all this?
thanks john
Old May 29, 2023 | 07:36 PM
GeorgeLG's Avatar
Do you have access to a scope, even a cheap little battery powered one so you can see if there is any data on the class 2 bus from the computer?
George
Old May 29, 2023 | 10:15 PM
Scubacarib's Avatar
yes would i test it at the back of the computer i striped a small piece about 1/8 but did not cut it
and thanks for all the help
John
Old May 29, 2023 | 10:42 PM
GeorgeLG's Avatar
Follow what the guy does in the video in post #6. If you get nothing even with the comb out after trying all the pins then yes go to the connector at the engine computer and try the dk grn class 2 wire there. Make sure that the truck is running for all of this.
George
Old Jun 2, 2023 | 10:14 PM
Scubacarib's Avatar
i got a scope and found a data signal and had a signal on the data bus but no communication to scanner what are the 4 wires to obd2 connector i assume 12v and ground and data is there a data ground also? anyway the engine runs good but it kicks back on first start it will stay running good if you turn it off after it runs even just 10 seconds it starts just fine
Old Jun 3, 2023 | 10:33 PM
GeorgeLG's Avatar
DLC pins:
2 ppl class 2 data
4 blk ground
5 blk/wht ground
9 tan VIU
13 org transfer case module
16 org +12v
Did you still have class 2 bus data traffic with the com reinserted?
George
