Codes just keep coming
Old May 9, 2019 | 03:51 PM
JamesL3's Avatar
JamesL3 is on a distinguished road
Default Codes just keep coming
So I had a misfire on 2 cylinders and the O2 sensors were trash. Changed the plugs,wires, cap, rotor, ignition coil and all 3 o2 sensors. Now I have a misfire on cylinder 6 and an evap code. Am I wrong in thinking my cat is toast? No smell, but bogs down a bit when I first get moving and runs a little rough. I want to get it mechanically sound before I start building it up. Only has 131k miles on it and a 2000 2 door 4x4.
Old May 9, 2019 | 07:12 PM
cleburne red's Avatar
Cyl 6 misfire and evap doesn't make me think of a bad cat. There is a code for low catalyst efficiency, that's the code you would see for a bad cat
Old May 9, 2019 | 09:23 PM
GeorgeLG's Avatar
You can test the exhaust back pressure in front of the cat using an O2 sensor port and/or shoot a few spots with sn IR temp gun to see what's going on
George
Old May 10, 2019 | 03:40 AM
Mike.308's Avatar
A misfire might be also related to a fuel pump problems, so You may want to test the fuel pressure too. It's in a sticky topic.
Old May 10, 2019 | 07:49 AM
motorbreth77's Avatar
motorbreth77 is on a distinguished road
How did the plugs look?
Especially in the cylinders that were misfiring?
Also did you use AC Delco for Cap/Rotor replacement?
These engines are picky about ignition parts.
I had a off brand Dist cap crossfiring underneath years ago.
Caused all kinds of problems, ACDELCO all the way
Do a fuel pressure bleed down test
Springer
Jun 26, 2016 06:10 PM
inzone
Dec 31, 2014 10:13 AM
wwilkjr
May 9, 2014 10:12 PM
polarbear18w
13
Sep 23, 2011 01:27 PM
wicki5420
Aug 16, 2008 09:31 PM
