coil driver
Old Oct 10, 2010 | 12:09 PM
jonc's Avatar
jonc is on a distinguished road
Default coil driver
Can anyone tell me which is the coil driver circuit on the black connector for the coil.
Old Oct 10, 2010 | 06:58 PM
What are you driving?
Old Oct 10, 2010 | 08:10 PM
jonc's Avatar
It is a 93 blazer with a 95 4.3L vortec.
Old Oct 10, 2010 | 08:27 PM
You likely used the coil & distributor from the '93 so... I believe it is the white wire that goes from the ICM to the coil.
Old Oct 10, 2010 | 09:45 PM
jonc's Avatar
Thanks for the reply. Think I have that all figured out. It has an MSD ignition. It looks like the blaster ignition went bad. It had a 5900 on it had to replace it with a street fire. The wiring is all differnt with that ignition. Going to get a wiring harness tommorow and get all hooked up. Hope this solves my no spark issue.
__________________________________________________ __________________________________________________ _______
Well still no spark. Anybody got any idea's? Forehead is sore and I'm out of ideas.
Last edited by rriddle3; Oct 11, 2010 at 03:41 PM. Reason: COMBINING CONSECUTIVE POSTS. PLEASE USE THE 'EDIT' BUTTON TO ADD TO A POST IF NOBODY HAS REPLIED WITHIN 24 HOURS.
Old Oct 11, 2010 | 08:29 PM
With such a mix of parts... You probably should get yourself a good manual (FSM) and go through the wiring and troubleshooting.
mamawolf70
Apr 10, 2020 10:44 AM
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
bjam2
Dec 3, 2005 12:39 AM
02 Vortech
Apr 14, 2005 11:53 PM
