coil pack noise
Old Dec 20, 2013 | 08:27 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
Default coil pack noise
Hey guy's 2002 blazer 4dr just started getting a new noise kind of hard to describe almost like something being spun ,Have traced it to my coil pack or distributer not sure which it is , looks like a coil pack ,anyway seems to be coming from under it any ideas on what it could be?
Old Dec 21, 2013 | 12:00 AM
cctcct67's Avatar
cctcct67 is on a distinguished road
2002 I believe that's the distributor your talking about it also has a single coil too. Are you talking about the rear of motor where all the plug wires run to (distributor) or mid way up passangers side of motor where coil is, it has a single wire from it going to distributor.
Old Dec 21, 2013 | 06:39 AM
it is at the rear of the vehicle a flat box that my wires plug into and funny i am not getting any codes at all
Old Dec 21, 2013 | 09:53 AM
metalmeltr's Avatar
metalmeltr is on a distinguished road
Distributor cap?
Old Dec 21, 2013 | 01:35 PM
yea that's it wow i am getting old that is not what i remember a distributor cap looking like, been a long time since Ive had to deal with one of these thanks guys
Old Dec 21, 2013 | 04:36 PM
cctcct67's Avatar
Is the noise a crackle like its arching out or is it metallic sounding? If maybe arching out try running truck at night see if you can see it arch. If its metalic I would pull the cap for start and see if everything's clean and still together (just have to remove 2 torqe bit screws). Also check to see if there is play in distributor gear at this point. You may want to pull distributor all together to make certain no problems( make sure you mark for install there are many threads here to explain removal and install). The injectors are also close to there make sure that's not the sound you are hearing.
Old Dec 21, 2013 | 08:05 PM
Thank you will pull the cap and inspect I will have to wait till after Christmas but thats ik won't be using the blazer anyway, I have to admit first thought was the injectors ,But when I touched the cap I could feel something, must be arcing
Old Dec 21, 2013 | 08:14 PM
richphotos's Avatar
If you want to see if its arcing... when its dark out, take a spray bottle of water and lightly mist around the back there, see if you see any sparks.
Old Dec 22, 2013 | 12:20 PM
LannyL81's Avatar
I suspect the noise you are hearing is the rotor rubbing the inside of the distributor cap.
Test this way. With engine running, grab the distributor cap with your hand and you will likely feel a vibration. Try slightly twisting the cap or pushing the cap down or pull it up and see if the vibration/noise goes away. Do not apply alot of twisting or pressure as the distributor cap screws are into thin plastic and are easy to break.
The problem is likely due to worn distributor bushings. The fix is cheap....get a new distributor...an aluminum housing one...about $50. Bit of a pain to replace due to the limited work area, but not too bad. Check ebay for the distributor; comes with new cap/rotor...not the best of course and for sure not Delco...but will last for awhile...just plan on replacing the cap/rotor with Delco parts.
Good luck.
Old Dec 22, 2013 | 02:01 PM
2000blaze's Avatar
2000blaze is on a distinguished road
i think i might have the same noise you have i narrowed it down to the plug and fuel lines that go into the intake itself i used a wood dowel to hear it there. i shot a small video its kid of like a grindish type noise more lower end rpms then any thing.
