coils packs starting to go??
Old Jun 30, 2008 | 06:06 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
Default coils packs starting to go??
is there any signs that coil packs are starting to wear out and if so what are they and how quickly should they be addresed??
Old Jun 30, 2008 | 06:18 PM
lfuller11's Avatar
lfuller11 is an unknown quantity at this point
Default RE: coils packs starting to go??
You might see some white arcing marks from either the wires, or on the pack itself.
Old Jun 30, 2008 | 07:31 PM
You will start to get random misfires, worse while under load. It will get to the point where you won't be able to drive the thing because it won't be producing a hot enough spark.
Most often, the overmolded plastic case will crack due to corrosion on the coil stack.
thilly26
Headers, Intake, & Exhaust
Sep 5, 2014 12:51 PM
jimmy1996
Performance & Brainstorming
May 3, 2009 04:26 PM
CashSax
Feb 3, 2007 06:07 PM
BlaZeR FXB1581
Suspension Tech
Apr 3, 2006 02:52 PM
tayzoid1
Feb 22, 2006 12:22 AM
