Collapsed lifter
Old May 9, 2016 | 08:35 AM
Impact's Avatar
Impact is on a distinguished road
Default Collapsed lifter
I am going to make a very long story short. I just got done putting and did put new lifters in and one is not pumping up and can be pushed in be hand. Is there any way of fixing this without changing it out? When I first started the engine after putting it in the lifter noise started and never stopped. Oh, I have a 99 blazer 4wd with the 4.3.
Old May 9, 2016 | 11:43 AM
LesMyer's Avatar
If one lifter is not pumping up then it is probably due to lack of oil pressure. Probably bad bearing fed from same oil passage. Doesn't matter if you just put them in. Your story is a little confusing to me. Not sure if you replaced the engine that had the nut run through it or if this is the engine you said had new bottom end parts.
Old May 9, 2016 | 12:56 PM
Impact's Avatar
It was the engine that was repaired and the head redone. The oil pressure is fine on the engine, the other lifter is ok.
Old May 9, 2016 | 02:17 PM
LesMyer's Avatar
Why don't you just put another lifter in it. I imagine you can get the parts store you bought them from to warranty it. If the new lifter remains collapsed you will have to blame oil pressure for that lifter. If it fixes it then great.
Old May 9, 2016 | 03:29 PM
Impact's Avatar
Just got a new onw and already installed it. The old new one was definitely bad. Im hoping for the best
Old May 9, 2016 | 04:30 PM
LesMyer's Avatar
Good luck!
Old Oct 5, 2017 | 02:30 AM
GreenBlazer2002's Avatar
Did that fix the problem?
Old Oct 5, 2017 | 07:18 AM
Impact's Avatar
Yes it did. Over 1 year later and engine still going strong.
Old Oct 6, 2017 | 07:46 AM
That's encouraging. There's a 94 full size truck selling for $800 that's in great shape except for the lifter issue. Considering buying it. Thanks!
gaspricessuckk
Feb 2, 2011 05:53 PM
Katmandu
Jan 11, 2010 09:33 PM
mudnsno
Nov 15, 2009 05:38 PM
Bob E.
Mar 31, 2006 11:39 AM
glenmoore670
Feb 15, 2006 11:08 PM
