Compass display stops working in hot sunny temps
Old May 15, 2011 | 01:45 PM
megaroos_00's Avatar
megaroos_00 is an unknown quantity at this point
Default Compass display stops working in hot sunny temps
After searching the forum I've come up with nuffin..
My 98 Blazer LT overhead compass (with sunroof) doesn't seem to display anything in hot sunny 70+ weather. I have the compass that displays MPG, range, temp and such. After sitting in the parking lot at work or in the driveway in the sun, the display doesn't seem to light up. However, in cooler weather, it lights up the display and works fine. And if I fooled with the buttons, may display whatever I got to like the range or cel instead of far measurement when it does light up again.
I'm at a loss whether this is a fuse or wiring issue since it does work and still seems pretty accurate with my direction/temp readings. Any thoughts would be appreciated.
Old May 17, 2011 | 06:50 AM
LannyL81's Avatar
If it was a fuse or wiring then it would never work. Most likely the electronics have become heat sensitive. You could try removing the unit and add some heat insulation between the unit and the roof to see if that helps. You may just have to replace the unit. I have seen used ones on ebay for not too much.
Good luck
Old May 19, 2011 | 07:44 PM
Hmm.. Was hoping to not have to replace it, it still seems to work just fine at other times. Think I will try the insulation and keep looking into a possible reason.. Thanks
jweber228
Mar 21, 2012 12:33 PM
mritech
Nov 26, 2010 07:53 AM
dravengary
Nov 9, 2009 10:36 PM
Rob02150
May 5, 2009 07:47 AM
DaddyCop03
May 11, 2008 09:07 PM
