Compiled List of Common Fixes
Old Nov 15, 2010 | 11:39 AM
  #21
zkilla396's Avatar
zkilla396 is on a distinguished road
You should add a fix for spare tire swing arm not un-latching. Don't know if others have had this problem, but all I did was put a slight bend in the bar connecting the handle to the latch mechanism (bar was too long to properly engage latch) - worked like a charm!
Old Dec 14, 2010 | 12:06 PM
  #22
mjw644allmand's Avatar
mjw644allmand is on a distinguished road
The rear window latch repair is well documented on this forum...I did my wife's about 18-months ago.
First key to success is the manual release of the window latch from inside. On my wife's 02 there is a small access hole centered along the top of the carpeted portion of the tailgate door panel. Through that hole you can manually release the glass - then drop the tailgate to remove the panel.
Easy to replace the clip on the end of the latch release actuator once you get that far.
Old Dec 14, 2010 | 12:26 PM
  #23
chevytruckdood's Avatar
i like this list!!!!!!!!
Old Dec 15, 2011 | 08:57 PM
  #24
tls00blazer's Avatar
tls00blazer is on a distinguished road
I had a "knocking" noise that it thought was a bad shock mount. Replaced shocks and mounts were good. Replaced ball joints. Not it. New steering bushings. Nope. 2 years later we were driving on an unpaved road. I had popped the hood latch so that hood would shake open by the time we got back to cabin so I could check oil. Hood came open and when it did gf says "hey your noise went away!" Turns out hood wore thru rubber gasket near hinge and was knocking metal to metal. Found piece of foam held it there and shut hood on it. NO MORE NOISE!!!! forgot to check oil. Had to drive more bumpy roads to get hood open!!! Of course there are better ways to fix it but the foam kinda formed itself in place being pinched in there n all so ..why fix what ain't broke?!
Old Dec 15, 2011 | 11:28 PM
  #25
rpeastep's Avatar
rpeastep is on a distinguished road
I can't tell you how many skinned knuckles I got before I discovered that little spring squeezer tool for the door hinges. That is a job that needs not be put off though. I left mine too long once and after all the door slamming I actually cracked the metal door post and now it is even harder to close. Need to get the crack welded one of these days.
On the tailgate latch, my '97 didn't have an access hole but it does now. Took a small hole saw and made a custom one.
Old Jan 1, 2013 | 10:30 PM
  #26
DMD8193's Avatar
DMD8193 is on a distinguished road
This list will definitely be put to use this weekend! Great job!
Old Jan 2, 2013 | 05:42 AM
  #27
chestypuller's Avatar
Banned
chestypuller can only hope to improve
cracked the metal door post? can you post a picture of that? i think i have a similar situation.
Old Aug 4, 2013 | 08:54 PM
  #28
Sparky8542's Avatar
Sparky8542 is on a distinguished road
There is some great info in here!
Old Aug 9, 2013 | 11:31 AM
  #29
Timbl's Avatar
Timbl is on a distinguished road
Also on the spark plug that is hard to get to, Slide the rubber boot on the steering rod down out of the way to gain better access. I did not know it slid and wasted a hour try ing to get past it.
Old Aug 9, 2013 | 02:21 PM
  #30
jimspahr@msn.com's Avatar
This list is great. Especially to those like me who are new to Blazers, 4WD , and 4.3L V6's. Keep up the good work. It would help me a lot to have more photo's, diagrams, drawings, of the solution. Thanks.
