console selector cant shift up
Old Sep 6, 2011 | 09:16 PM
chimacc's Avatar
chimacc is on a distinguished road
Default console selector cant shift up
at frist i could not shift in to park at all .every thing else worked fine r,n,d,o,1, I was manually putting the transmission in park now all i can do is down shift were be fore i could at least put it in neutral and reverse .
is this a cable problem or a shifter column problem?
what part s\brand should i by to replace
i found a doorman 326 905-101 on amazon $61 bucks new but cant find the wright cable too buy
Old Sep 6, 2011 | 10:01 PM
What are you working on? The '78 Blazer in your 'garage' doesn't use a shift cable.
Old Sep 6, 2011 | 10:11 PM
chimacc's Avatar
ok sorry about that i put my birth year
its a 1996 blazer Ls i fixed the date on my profile
Old Sep 6, 2011 | 10:20 PM
It sounds like a problem with the shift cable. Can you disconnect the cable at the transmission and move the shifter through the appropriate range of motion?
Check out the schematics on THIS PAGE (courtesy of Compnine.com). The OE part numbers are also listed if you click on the applicable schematic (floor shift - AC Delco 15713353 or column shift - AC Delco 15721261).
Best to keep the information in your garage applicable to the truck you have or put the proper information in the post requesting for help.
Old Sep 6, 2011 | 10:24 PM
chimacc's Avatar
wow thanks for the links
and i will try to see the range of motion with the cable removed from the transmission 2 nite i never took it off before
Old Sep 6, 2011 | 10:27 PM
You can try disconnecting it at both ends. Then shift the transmission from park to low, measuring how far it moves from one to the other & noting if it gets difficult to move at any point (other than the detents themselves). The cable should move more than the transmission shift lever does.
TAZ454
Sep 10, 2014 06:15 PM
dsevern
May 24, 2012 09:17 PM
dreadinger
Aug 3, 2011 03:41 PM
vracer99
Apr 28, 2011 08:54 PM
aura1
Nov 4, 2010 12:42 AM
