Coolant drain amount?
Old Sep 4, 2018 | 02:02 PM
Default Coolant drain amount?
Hi all,
Quick question, how much of the coolant can be drained using only the radiator drain? I know the total cooling system capacity is 11.7 qts.
Old Sep 4, 2018 | 04:59 PM
Mike.308's Avatar
I remember my story that comes with radiator petcock valves. They quite often gets clogged, stuck or leaking if You manage to open them somehow. So in vast cases people used to pull off the bottom radiator hose to drain. The amount drained that way doesn't have much in common with a radiator's volume.
I've replaced my radiator and still keep the old one. I can measure the volume if no answers
Old Sep 5, 2018 | 04:19 AM
dlundblad's Avatar
dlundblad is on a distinguished road
For easy math, I'll just say the system holds 12 quarts.
I believe you can get 4-5 out by removing the lower radiator hose and letting air into the system by unbolting the thermostat housing.
No false Bravada
Jul 10, 2015 07:28 PM
B761953
13
Oct 29, 2013 02:42 PM
Wendover
Sep 15, 2011 06:18 PM
ComputerNerdBD
Jul 10, 2011 12:54 AM
FemmeVamp
May 22, 2007 01:09 PM
