Coolant Temp sensor location????
Old Oct 31, 2011 | 06:32 PM
MrRedBlaze04's Avatar
MrRedBlaze04 is on a distinguished road
Default Coolant Temp sensor location????
got a 2004 zr2 blazer can someone tell me where the coolant temp sensor is located? gotta get the old one switched out.
Old Oct 31, 2011 | 07:46 PM
Driver side cylinder head between cylinders 3 & 5 on the side of the head.
Old Oct 31, 2011 | 09:57 PM
The sensor for the dash gauge is in the driver side cylinder head as Kyle mentioned. The engine coolant temperature sensor, (ECT) for the OBDII is next to the thermostat housing.
Old Nov 1, 2011 | 01:55 PM
it has threads on it right? and screws into the block?
Old Nov 1, 2011 | 02:04 PM
2004 == only one sensor, not separate sensors. That happened in '99 if I remember correctly which is when the BCM took over controlling the dash and talked with the PCM for its information instead of pulling directly from sending units & sensors. My '00 Bravada only had the one, two-wire sensor in the driver side head and just a blank, un-machined boss on the lower intake manifold where the 96-98 ETC sensor went.
The location for all 99+ is in the driver side cylinder head threaded into the head. The hole that it threads into opens up into the coolant passage in the cylinder head so expect to loose some coolant in the process. Have the new sensor ready to put in right away to minimize the lost coolant.
Attached Thumbnails Coolant Temp sensor location????-etc_sensor_location.gif
Old Nov 1, 2011 | 02:13 PM
Good call on the single sensor and class II communications! (I missed the 2004)
Old Nov 1, 2011 | 02:36 PM
Mike7075's Avatar
Mike7075 is on a distinguished road
Just to clear up auto parts jargon, the sensor for the computer is the temperature sensor, the sensor for the gauge is the temperature switch. That will ensure you get the right thing when you ask the kid behind the counter. As for the later model single sensor... I dunno.. Temperature Sensor Switch?
Old Nov 1, 2011 | 02:47 PM
Originally Posted by Mike7075
....As for the later model single sensor... I dunno.. Temperature Sensor Switch?
Doesn't really matter what they call it, there's only one. So as long as the kid behind the counter can look it up, you should get the right part
Zach8846
Mar 14, 2014 07:06 PM
epederson
Nov 15, 2012 01:36 PM
7designs
Jun 23, 2011 07:33 AM
zakm0n
Jan 9, 2011 07:31 PM
stidrvr
Feb 8, 2006 12:16 PM
