Correct wheel bearing-hub for 1999 Blazer ZR2. Is this the right bearing?
I think the wheel bearings is worn on the right side front right wheel on my 1999 Blazer ZR2.
It can also be a CV joint but i that was the case you would hear the noise more when you are doing a tight turn which is not the case with my car. I guess this is because i have never used the Blazer much at wintertime and because og that i usually drive with rear wheel drive 99,9 percent of the time. But this winter i have used the Blazer every day and in 4 wheel drive mode all winter. Since i have no idea i will ask here. Any here on the forum that knows if a 1999 Blazer ZR2 use use "special" wheel bearing-hub`s or can you use regular 1999 Blazer 4WD wheel bearing-hub`s? This is for the front wheels Here is a couple of pictures of the wheel bearing/HUB from Rock Auto SKF wheel bearing/HUB. Picture 1 https://cimg1.ibsrv.net/gimg/blazerf...1b8744edd0.jpg SKF wheel bearing/HUB. Picture 2 https://cimg7.ibsrv.net/gimg/blazerf...c6b112bf04.jpg |
Originally Posted by TheSaint
(Post 752383)
