Correct wheel bearing-hub for 1999 Blazer ZR2. Is this the right bearing?
Old Mar 26, 2024 | 06:40 PM
TheSaint's Avatar
TheSaint will become famous soon enough
Default Correct wheel bearing-hub for 1999 Blazer ZR2. Is this the right bearing?
I think the wheel bearings is worn on the right side front right wheel on my 1999 Blazer ZR2.
It can also be a CV joint but i that was the case you would hear the noise more when you are doing a tight turn which is not the case with my car.
I guess this is because i have never used the Blazer much at wintertime and because og that i usually drive with rear wheel drive 99,9 percent of the time.
But this winter i have used the Blazer every day and in 4 wheel drive mode all winter.
Since i have no idea i will ask here.
Any here on the forum that knows if a 1999 Blazer ZR2 use use "special" wheel bearing-hub`s or can you use regular 1999 Blazer 4WD wheel bearing-hub`s?
This is for the front wheels
Here is a couple of pictures of the wheel bearing/HUB from Rock Auto
SKF wheel bearing/HUB. Picture 1
SKF wheel bearing/HUB. Picture 2
Old Mar 27, 2024 | 05:05 AM
Freeman13's Avatar
Freeman13 is on a distinguished road
Hi, I changed mine recently on my zr2 no compatibility problem. only the CV axle changes size with the ZR-2.
DaveP78
Oct 4, 2018 05:49 AM
nasiraod
Nov 21, 2017 11:47 AM
tibby
Oct 2, 2011 11:37 PM
metalhead
Nov 28, 2008 02:46 PM
Loud_01_Blazer
Oct 4, 2006 02:20 PM
