crank sensor
Old Jul 25, 2014 | 07:50 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default crank sensor
long story short, truck wont start, tried the starter fluid in the intake, no start
friend had me look at the crank sensor. lot of gunk on it. wiped off and tried to start. started instantly and then cut off. lightly tapped the sensor with a screw driver. immediately started...lasted 6 seconds and shut off
does this mean crank sensor is bad?. was told i can check ohms...idk how
also how do i properly check voltage of wires that lead to it, thinking there might be a short if its not a bad sensor
Old Jul 26, 2014 | 12:05 PM
burned's Avatar
burned is on a distinguished road
Old Jul 26, 2014 | 02:43 PM
er0ck273's Avatar
do you happen to know what the oem sensor is with part number in applicable?
Old Jul 27, 2014 | 03:19 AM
GaBear's Avatar
GaBear is on a distinguished road
DELPHI Part # SS10125
ACDELCO Part # 2133208
Old Jul 28, 2014 | 03:18 PM
er0ck273's Avatar
awesome! thank you
Buddykitchen
Dec 10, 2016 06:37 PM
Tony H
Sep 7, 2010 07:45 AM
g_mike
Aug 22, 2010 02:46 PM
GM hater
Jan 9, 2010 02:32 PM
Bybsurfr32
Sep 23, 2009 09:12 PM
