Cranking Time Before Starting
Old Dec 29, 2022 | 10:28 AM
lathechips's Avatar
lathechips is on a distinguished road
Default Cranking Time Before Starting
It seams like it takes about 5-8 seconds cranking time before starting. Is that normal ?
Old Dec 29, 2022 | 01:11 PM
No.
Don't for get to tell everyone what you have; year, # doors, 2 or 4-wd, etc.
Old Dec 29, 2022 | 02:27 PM
lathechips's Avatar
2001 S10 Blazer 6 cyl. auto
Old Dec 29, 2022 | 03:33 PM
LesMyer's Avatar
Should start first turn of the engine - even when fully cold. Mine does. Never had a car start so quickly or so well. So no, that's not the way it's supposed to be.
Old Dec 29, 2022 | 03:34 PM
rockp2's Avatar
The first thing I would do is listen for the fuel pump prime by turning your ignition to run and "aiming" your ears toward the rear of the truck. It should prime for ~2 seconds. Note there is also a buzz that comes from the IAC valve under the hood. So insure you're hearing the pump.
In the event you are not getting power to the relay from the primary signal, your oil pressure sensor will send the power to the fuel pump once oil pressure reaches 4 psi. Which is why it will start after a long crank. It's not actually for that purpose, it's actually a GM safety device in event of an accident. But regardless, it will still provide power to the pump.
If you do hear fuel pump prime, I would cycle the key from off to run a few times with ~10 seconds in between each cycle and then try to start the truck. If it seems to fire up correctly, I would head in direction of Fuel Pressure Leakdown test (link below my signature)
When you go to start watch your tach very closely. If it's a long crank, you should see your tach needle flutter just a tiny bit. If it stays rock steady bottomed out, I might look at the Crank Position Sensor as the problem and run tests on that....
EDIT:...at the same time I would be considering Fuel Pump Relay. Especially if tach needle does flutter a tiny bit.
EDIT2: Need to correct myself (already deleted above) oil pressure switch gets power from the same fuse as pump, so pump wouldn't run at all if fuse was blown. Don't know what I was thinking.
Old Jan 30, 2023 | 08:54 PM
jimmy3221's Avatar
jimmy3221 is on a distinguished road
Get a 15 dollar fuel pressure gauge from harbor freight sounds like your not holding fuel pressure my 01 jimmy did this when the spider assembly started going out
tressia
Oct 7, 2014 11:16 AM
chickenhawk
Aug 25, 2013 10:05 AM
jcouch44
The Chop Shop
Mar 26, 2013 09:37 PM
XtreemeBlazer
May 16, 2010 12:09 AM
BruceG07
Feb 11, 2009 08:58 AM
