cranks and cranks and cranks
Old Jul 11, 2011 | 03:26 AM
bsbob's Avatar
bsbob is an unknown quantity at this point
Default cranks and cranks and cranks
2001 blazer-80,000 miles-run ok- stranded me -got it towed home-started it and it started-then it wouldnt-so we changed the fuel filter-started up-drove it to work for 2 days no problems now back to the endless cranking.from what ive read on here it sounds like probably the fuel pump but i also read about a fuel pressure regulator-not looking forward to changing fuel pump but i read about water in the gas and we just had a huge rain???any thoughts would be very much appreciated
Old Jul 11, 2011 | 05:58 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
As the old saying goes: Spark and Fuel, Are you getting both?
Old Jul 16, 2011 | 10:53 PM
R134A's Avatar
R134A is on a distinguished road
Check fuel pressure
Old Jul 17, 2011 | 10:39 AM
bsbob's Avatar
well the gas tank is off now i just gotta get the new fuel pump and put it in-it wasnt as hard as i thought but not in a hurry to do it again-i really hope it starts!!!
Old Jul 18, 2011 | 02:50 PM
ncpatsfan's Avatar
ncpatsfan is an unknown quantity at this point
do you have fuel pressure at the rail. check with a fuel pressure gague. If you have none could be bad relay or bad pump. If you have fuel pressure but will not fire up could be a bad ignition control module. Check out this website to troubleshoot it.
Part 1 -GM 4.3L, 5.0L & 5.7L Ignition Control Module (ICM) Test.
Apparently they are known for going bad when they heat up. Start you but when you heat up the car you can crank with no start. Good luck
Old Jul 22, 2011 | 12:48 PM
bsbob's Avatar
wow it worked!!!new fuel pump nowshes runnin-very thankfull 4 this forum
kwbond
Mar 18, 2014 12:39 AM
treysanatomy
Oct 30, 2009 07:36 AM
JMAC
17
Apr 7, 2009 11:32 AM
lovetoblaze
Mar 31, 2009 09:01 AM
nyjeepman
34
Mar 15, 2009 07:40 PM
