Crank, Cranks, and ranks won't start until?
Old Oct 10, 2009 | 02:59 AM
treysanatomy's Avatar
treysanatomy is on a distinguished road
Default Crank, Cranks, and ranks won't start until?
I tried all starting fluid I had and it tried to start. I put just a bit of gasoline in each side of tbi and it fired right up. I am right that it is the fuel pump or completely clogggged filter? I took supply line loose from tbi turned key on and could see no gas being pumped nor could I hear the fuel pump back at the tank. I am at a loss, PLEASE ADVISE
Old Oct 10, 2009 | 07:34 AM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
sounds like you have a bad fuel pump
Old Oct 10, 2009 | 02:07 PM
Corrupt's Avatar
Corrupt is on a distinguished road
Yup, most likely a bad fuel pump, but if you have a voltmeter check the voltages on the wires before going thru the hassle of dropping the tank.
Old Oct 10, 2009 | 10:57 PM
94blueknight's Avatar
94blueknight is on a distinguished road
if u dont hear the 'buzz' of the fuel pump turning on with the key in the on position then yes with your symptoms it is most likely the fuel pump that is bad
Old Oct 30, 2009 | 07:36 AM
Default Problem fixed
I Followed each and every suggestion to the letter, doing so It helped my moronic complex. Thanx to the guys for chewin my butt off, it worked. I repfalce all fuelo pump goodies and it runs like a champ. New fuel filter, complete internal cleening of the fuel teank. I wanna sai thanx, i apologize fro jumping to conclusions and getting my azz chewed up in oer to line me out. As always thanx a million.
Buddykitchen
Dec 10, 2016 06:37 PM
kwbond
Mar 18, 2014 12:39 AM
bsbob
Jul 22, 2011 12:48 PM
Colby 04
Apr 14, 2009 10:57 AM
nyjeepman
34
Mar 15, 2009 07:40 PM
