Cranks with no start
Old Oct 18, 2020 | 02:07 PM
  #41
GeorgeLG's Avatar
I've not done the upgrade myself but I am pretty sure that the LIM stays put.
George
Old Oct 18, 2020 | 02:24 PM
  #42
whislinwings's Avatar
whislinwings is on a distinguished road
Guess I will find out either way. Thank You again George. I learned a bit!
Old Oct 18, 2020 | 03:18 PM
  #43
GeorgeLG's Avatar
Let me know how the balance test comes out when you pulse the injectors. That's the last test before tearing into the intake manifold. Your doing a good job of analyzing your problem so that you can confirm the correct repair.
George
Old Oct 25, 2020 | 12:39 PM
  #44
Update. Learned the issue may be bad gas.. My lil girl had the same problem with her car. Her shop found it was bad gas. She was driving my blazer when it acted up. Asked if she fueled blazer from same station she says "Yes". So in the process of trying to draining my tank, I blew a fuse or something when I tried the "Paper Clip" trick.Now I get no power to fuel pump when I turn the key . any ideas what I did?
Old Oct 25, 2020 | 01:26 PM
  #45
GeorgeLG's Avatar
What's the paperclip trick?
Where are you measuring no power?
George
Old Oct 25, 2020 | 01:35 PM
  #46
GeorgeLG's Avatar
Check the ECMB fuse - 20A
George
Old Oct 25, 2020 | 01:42 PM
  #47
Paper clip- pull fuel pump relay and jump to keep fuel pump running... I did not learn of the female plug next to FP relay. Ok George I will check now TY
Old Oct 25, 2020 | 01:54 PM
  #48
Found ECM 1 fuse blown. I will go get some fresh gas and report back. Thank You again George!!
Old Oct 25, 2020 | 02:11 PM
  #49
GeorgeLG's Avatar
If the fuel pump is working I pump bad gas out through the fuel rail schrader using a cutoff old HVAC charging hose. Careful.
George
Old Oct 25, 2020 | 03:19 PM
  #50
I drained from filter connection. Update.... Fresh gas and it's alive!! Running like crap but running. Got a po108 code.
