Crazy Vibration.. Please read, help needed
I have a 1995 s10 blazer lifted a bit. I put a new (reman) passanger side axel shaft in it becuase my boot was ripped (no other issue) When i went and drove it vibrates and shakes like crazy so i figured i got a bad one, so i put a NEW one on. Still does the same thing after you hit 30mph it just shakes and vibrates like crazy. I even went and had a new boot put on my old one (which i had no issues with) and it does the same thing?? Please help i need to be able to drive my truck but i can. Any input would be greatly appreciated Thanks
i had a 92 jeep chero that did that around 53-62, never figured it out, however i have a 1995 blazer that did that at 60-65 and smoothed out under 60 and over 70, i didnt know what in the hell it was untill 1 day it did it at 45 the worse it got the more i slowed down 3 seconds later the tread blew off the tire, the treat looked good, had depth still and plenty of it, and the tire did NOT blow held 32psi just the treat blew off, so try looking into that issue, a put the spare on and it didnt do that, a week later got new tires, still hasnt done it to this day, will run 90 now and smooth as a babys bottum, good luck!
Did you get the tires road force balanced? Some times have defects in them that only show up when the tires are balanced while simulating the weight of the vehicle on them which is what road force balancing does.
Maybe rotate the tires front to back? It'll atleast tell you if its the tire or a suspension issue.
kevinph
02-25-2019 09:24 PM
opposedforces
09-01-2011 02:59 PM
buck8907
09-17-2009 06:15 PM
