cruise control
Old Jun 9, 2011 | 01:28 AM
darknight's Avatar
darknight is on a distinguished road
Exclamation cruise control
My cruise control on my 2001 blazer lt doesnt work.... how can I fix this?
Old Jun 11, 2011 | 12:56 AM
wrenchturner3529's Avatar
wrenchturner3529 is on a distinguished road
1. check the fuse
2. check the brake lights to ensure they work or are not stuck on (voltage from the brake light switch deactivates the cruise control)
3. check the cable linkage between the cruise control actuator and the throttle linkage. The cruise control module is located on the driver's side firewall.
4. check the wire connection at the cruise control actuator look for damaged or broken wires.
5. check the speed sensor . 2wd its located in the transmission housing near the output shaft. 4wd its located on the top left rear of the transfer case. Disconnect the connector and use a multimeter to probe the wires and check for about 5 volts between the yellow wire (+) and purple wire (-).
6. you can take the truck to Auto Zone or other place and have a scanner test ran for trouble codes 24 or P0500. If these are found there's a problem with the speed sensor control circuits.
hope this helps
Old Jun 11, 2011 | 10:17 AM
darknight's Avatar
K thanks... o be had da truck scaned before in da past and I was told it had no codes... but my cruise control set button and on and off switch looks worn out... could dat be a facter as well?
Old Dec 26, 2011 | 02:11 AM
darknight's Avatar
Anything else I can do to fix this?
88jimmah
Oct 11, 2007 08:11 PM
982DRBlack
Jun 27, 2007 06:39 PM
6wraith
Jun 27, 2007 12:44 PM
rjar5
May 1, 2007 10:11 PM
drefda
Jun 13, 2006 01:31 PM
