-   -   Ctsy Fuse keeps blowing (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/ctsy-fuse-keeps-blowing-72153/)
Derick Jul 10, 2012 02:27 PM
Having a problem with a ctsy fuse blowing and when it blows the push button indicator light for my 4wd goes out and 4wd won't work.The interior lights not working isn't that big of a deal but would like to know why it takes out my 4wd.The 4wd fuse never blows but quits working. Any help/suggestions would be appreciated.Thanks! Oh it's a 98 blazer btw.
swartlkk Jul 10, 2012 02:53 PM
*Moving to 2nd Gen Tech* - Gen Chat is for topics that really don't fit in another section.
How many buttons does your 4wd switch have?
Derick Jul 11, 2012 02:19 AM
It's got 3 buttons on it.
swartlkk Jul 11, 2012 08:01 AM
This post has the wiring diagrams that should lead you to the answer of why the CTSY fuse caused the lights to go out. I don't have access to photobucket from work so I can't view my own posted images... :icon_doh: But I know what's in there.
NV233 transfer case / encoding motor switch
c_hab420 Aug 29, 2012 10:03 PM
To anyone having the same issue with with the #8 ctsy fuse blowing instantly and disabling the 4x4 function and interior lights, I have just fixed this on a 2004 blazer zr-2 for a customer.He made the mistake of putting in a 30 amp fuse and melted some wires which made it harder for me to diagnose but after repairing the wires behind the fuse block i isolated the short to the driver side sun visor,as soon as i took the 3 screws out and the visor came down i saw that the wires were completely melted together up to the connector.I simply unhooked it and replaced the the 10 amp fuse and everything woke up,4x4 lights work and it engages and all related components are working properly.its very easy to check the visor wiring so i hope this helps someone.Took almost 5 hours to diagnose and repair.Electrical isn't for the faint of heart!
Derick Sep 10, 2012 10:42 AM
Well,checked the wires at both visors and they were good...good idea though I hadn't thought to check that. Still looking for the culprit
LannyL81 Sep 10, 2012 11:44 AM
Since that fuse is for just about all the enterior lights...you are going to need to check all of them. Try the easy ones first....the two footwell lights....perhaps one of the mounting screws went into one of the wires.
The glovebox light is probably next in line as easy to get to. Just drop the door down and pull the lens off to pull the light and wiring down.
I do not have a wiring diagram for this fuse and only going from memory as to what lights go out when pulling the fuse.
Did you disconnect the sunvisor lights when you had them down? It could be a wire inside the sunvisor itself....unlikely, but something to try to see if the fuse still blows.
Good luck
Derick Sep 11, 2012 11:57 AM
Yeah I left them disconnected for a day and still blew the fuse,I'll check the footwells and the glove box next,hopefully I'll find something!
