curious about gearing
Old Jan 30, 2009 | 11:50 PM
Bodar's Avatar
Bodar is an unknown quantity at this point
Default curious about gearing
what is the reduction ratio's for the t-case on a 99 blazer LS 4.3l? also wondering what the ratio is in the rear and front diffs? I got the factory locker in the rear, i was curious thought one of you guys would fill me in.
thanx for any replies
Old Jan 31, 2009 | 02:11 AM
WolfPack's Avatar
Default RE: curious about gearing
Your axle ratios will vary...usually either 3.42 or 3.73. To find out, look at the RPO codes in your glove box. GU6= 3.42, GT4 = 3.73
Use this handy Gear Ratio Calculator to find out your final drive/crawl ratio. Just in case you need to know, you have the 4L60E transmission (auto) or the NV3500 (should you have a 5-speed manual), assuming you have the 3-button electronic 4x4 you have the NP233 transfer case, but both the NP233 (electronic) and the NP231 (1st gen blazer floor shifted 4x4) have the same 2.71 low-range....so...for the calculator...use NP231.
Then just enter your axle ratio (found in glovebox) and your tire size, and hit calculate. It gives you lots of fun info
My final crawl is 28.3:1. Woo!
Old Jan 31, 2009 | 09:49 AM
Bodar's Avatar
yes i do have the automatic and i have the electronic 4x4, with the auto 4x4 function. Thank you for that info.
Unlimitedsp
Tires and Wheels
Dec 3, 2008 03:58 PM
jimbosv650
Feb 18, 2008 01:50 PM
ripoffblazer
Jun 7, 2007 10:06 AM
juscarter
Dec 26, 2006 09:53 AM
TheDesertFox
Aug 15, 2006 01:07 AM
