Current situation..
Hi xxEddie, looks like it could be a grounding issue, maybe. Have a friend whom had issues with his blazer for two years. He was older and didnt want to go deep on a repair. He took the truck to the dealer. After ten days of headaches at the dealer they took the entire dash out and found the big/main wire bundle where it comes close to or through the steering column brace-formed metal frame work had worn through the wire insulation and the resulting intermittant arcing was makeing big trouble.The repair was expensive and he was disgusted with the truck problems. Sold it. I would never have guessed that one.
Captain, notice you say use AC Delco original parts. I have also heard others say when replacing the fuel pump be sure to use original because others may give problems. Are these things that temperamental? Just seems like any named brand good plug would work as well. No?
As for plugs, several members use NGK and have good luck with them. I don't count on luck, I use AC Delco 41-993 with a gap of .060" (that's what came in it when it was new).
I have an airtex pump in my 97 blazer for 6plus years not a problem, guess it's the luck of the draw with any part you buy, regardless of manufacturer! I would try replacing the complete distributor, can get them for $52 on ebay shipped from Skip White, better made than factory with aluminum housing & brass terminals, plus 5 yr warranty! Good Luck!
Local Chevy dealership pulled 4 codes.. MAF, EVAP, EGR, and throttle pedal sensor.. which I've never heard of.. I replaced maf with one from pick and pull.. now it acts funny if I take off slow..
#1 Check fuel pressure and leakdown, and post the results.
#2 Find out exactly what DTC's are in memory and post them.
Some vehicles have a "throttle pedal sensor", yours does not. Yours has a throttle position sensor. If the dealer doesn't know that, find a new dealer
