CV axils?
Old Mar 15, 2012 | 12:37 PM
NEW YORK BOY's Avatar
NEW YORK BOY is on a distinguished road
Default CV axils?
hey guys, i have a 96 blazer and up front i hear a lot of clunking when i turn and stop fast. i think its the CV axil. when i jack the front up and turn the wheels full lock one way i can wiggle the cv axil on both sides. and one of my boots is ripped. if it is the CV axils can i remove them and still drive the truck? or do i have to have them on? i dont care to much if i wont have 4x4 because im tight on money right now. but any help from you all will be big help!
Thanks,
Jeff
Old Mar 15, 2012 | 01:05 PM
hzl6cm's Avatar
hzl6cm is on a distinguished road
I kind of guess here, but I think if you do that you will be leaving big open holes in to your front differential plus I don't think your front hubs would stay together if you remove the front axles. I don't know how much axles ost for these but years ago a bought a CV joint kit for a vehicle from JC Whitney and just replaced a CV joint on a car while reusing the axles. It didn't cost to much to do it that way.
Old Mar 15, 2012 | 01:06 PM
alright ill look more into pricing. thanks
Old Mar 15, 2012 | 01:24 PM
the end that goin into the differential. what would make that wiggle and or what part would that be?
Old Mar 15, 2012 | 02:38 PM
spittybays
Guest
Posts: n/a
Under 100 re-built for the whole mugilla......
Old Mar 15, 2012 | 04:17 PM
oldsbravada2000's Avatar
oldsbravada2000 is on a distinguished road
Its probably the three ball-and-socket joints inside the boot they most likely started to separated and then when you went to stop they completely separated along with the boot. from your tire wanting to keep spinning while the vehicle doesn't. I would also check the splines on the end of the shaft that goes into the differential, make sure they aren't sheared off. were you running 2 different sized tires on the front? even if the tires were half an inch different in size it can tear **** up.
Old Mar 15, 2012 | 09:18 PM
nope it always had the same size tires all around. i just hope all this isnt going to be to much. but i do want to replace both sides.
