CV Axle Replacement Quick Method
Old Feb 9, 2011 | 06:37 PM
Benedict1337's Avatar
I really can't see that either I thought at the end of the boots were wider than the spindle hole
Old Feb 9, 2011 | 08:48 PM
dj00140's Avatar
dj00140 is on a distinguished road
has anyone done this on non-zr2 trucks? Do you pull it through the spindle hole? Or do you pull it out the differential and then back it out of the spindle and wiggle it out the side?
And the cv axles go into the differential not the transfer case! right?
Old Feb 9, 2011 | 09:43 PM
AJBert's Avatar
I think I screwed up, the CV goes into the diff. The transfer case is mounted behind the transmission. Except on the passenger side, the CV goes into the axle shaft/tube which goes into the diff.
Old Feb 9, 2011 | 09:56 PM
dj00140's Avatar
So have you done this on a non zr2?
Old Feb 10, 2011 | 11:13 AM
ddolin's Avatar
ddolin is on a distinguished road
Ive done a few axles. But i have yet to do a axle on my bravada. With my previsious experience the hardest part was to get the cv housing out of the stub shaft. Make sure you have a snap ring with your new axle. I read in manuels its not recommended to re-use snap rings. Try droping the lower control arm.
Old Feb 16, 2011 | 03:51 PM
dj00140's Avatar
Tried it and it didnt work for me... do you have to pull it out of the differential first?
Old Mar 14, 2013 | 12:11 PM
Ramjam2112's Avatar
Ramjam2112 is on a distinguished road
Default CV axle replacement
This is how I did it on a 95 blazer non zr2
Old Mar 14, 2013 | 01:00 PM
rexmburns's Avatar
Super Moderator
Awesome video! I like that you included part #s and tool numbers very helpful. My seals on my knuckles are bad on both sides and I tried to replace them when I had the truck torn apart last year but couldn't find the parts now I have them written down and ready to go if I ever take it apart again before my SAS.
PS: tell us how you really feal about autozone lol!!!
Old Mar 14, 2013 | 05:55 PM
xtrmes10's Avatar
xtrmes10 is on a distinguished road
It's not pulling the CV through the hole. By removing the hub it gives you more room to pull the CV shaft out of the front diff. Once you get the diff end out you can pull it back to get the end out of the hub.
Old Mar 14, 2013 | 06:37 PM
rexazz2's Avatar
I think that with the hub assembly out , if you turned the stearing wheel all the to stop
Then flex the outer joint and it might bypass the hole sideways
I dont think the shaft will pull out threw the bearing hole
