CV Boot Band Size
Old 09-27-2021 | 10:59 AM
Toxyco's Avatar
Toxyco is on a distinguished road
Default CV Boot Band Size
A search for CV band yielded nothing. The driver side inner (large) CV boot band is dangling in the breeze. The boot appears to be intact. Want to grease and replace the band. Does anyone know what size I should be getting?
Old 09-28-2021 | 04:31 AM
christine_208 will become famous soon enoughchristine_208 will become famous soon enough
I don't know the size but since it is off and you want to re-grease it, I'd suggest you consider removing the axle and replacing the boot with a neoprene one. I did this with a kit from NAPA. The kit comes with all that you need and the neoprene boots are better.
Also, if the original boot has slipped off, it is likely because there is damage to the inside of the boot allowing it to come loose.
Old 09-28-2021 | 06:41 AM
Toxyco's Avatar
Agreed that may be the way to go. I have to get in there and really inspect. The boot was not displaced and is semi-tight even w/o the strap. It may have just recently come loose with few miles in between.so we'll see.
LannyL81
02-15-2015 08:43 PM
matt9589
08-21-2013 09:55 AM
tony991
17
05-06-2010 01:05 PM
Dpepe79
08-18-2009 07:54 PM
ceanern
08-13-2006 01:10 PM
Quick Reply: CV Boot Band Size
