Cyl #4 misfire
Old Jul 20, 2017 | 02:30 PM
Justin56's Avatar
Justin56 is on a distinguished road
I haven't changed my spider yet. I'll post when I get it swapped out
Old Jul 20, 2017 | 02:51 PM
newguy's Avatar
When you take off the plenum it should be black underneath. shiny goldish color is a leak. No good
Old Jul 22, 2017 | 03:39 PM
GeorgeLG's Avatar
The leakdown test tells you that the pump develops proper pressure and that it is not leaking down in the pump, lines, injectors or regulator. What you still don't know is if the injectors are firing properly. For that you can do an injector balance test where you pressurize the system and pulse each injector the same and see if the pressure drops the same for all of them. Also, your misfire can be caused by spark (ECM/wiring/CMPR/coil/cap/rotor/distr/wires/plus) as well as vacuum or compression. What is your fuel trim on that bank both short term and long term at both idle and 2500 rpm? Did you do a compression test?
George
Old Jul 25, 2017 | 08:02 AM
Justin56's Avatar
Update... It was in fact the spider injector. The injector for Cyl 4 was shorted out. So for now the Jimmy is happy.
Old Jul 25, 2017 | 09:09 AM
newguy's Avatar
cool thanks for the update
Old Jul 25, 2017 | 02:00 PM
Justin56's Avatar
My injector spider had an electrical issue did a continuity test on each injector and #4 showed constantly open. changed the spider and the Jimmy is happy again
Old Jul 30, 2017 | 04:31 PM
joejiz's Avatar
joejiz is on a distinguished road
thanks for update. did distributor have to come out for intake to be removed? assume so.
Old Jul 30, 2017 | 04:53 PM
newguy's Avatar
no it doesnt, or you could just look
Old Jul 31, 2017 | 10:16 AM
Justin56's Avatar
Newguy is right the distributor does not need to come out.
Magman
Nov 16, 2010 11:57 AM
butters
Sep 19, 2010 12:01 PM
mattlinke
Jan 21, 2010 10:04 AM
vaportrail
38
Sep 21, 2009 05:38 PM
PhatKat
Mar 30, 2006 07:13 PM
