dash removal help
dash removal help
Hi, I've read everyones post's regarding blend door actuators and there replacement. What I haven't been able to find is anything specific on removing the dash or components to replace it. I have poor vision to start with (large font) but I'm truly blind trying to access this thing above the heater core. Any detailed instructions, photos or videos would be a huge help. This seems like a great forum and community. Thanks in advane to all that reply. ..Brian
1995 4wd blazer
1995 4wd blazer
Some members say it can be replaced by removing the glove compartment but i found it difficult.I followed the same procedure as removing the heater core. Disconnect the negative battery terminal!!!!! .On the top the screws are in the speaker locations ,just unscrew the grille to access the screws and the same for the defrost grille it pops open with a srewdriver.Two bolts on the steering column to lower it. Then there are 2 bolts by the kick panels .After that the dashboard should pivot foward.Pivoting the dashboard is fairly simple but accessing the screws to the actuator is somewhat time comsuming. Sorry i dont have any pictures but im sure someone in the forum should.Good Luck
Thanks for the help althogh a little late, it is still appreciated. We have had the dash out twice now for 2 seperate prblems. Even though it's been out twce I doubt I could have explained it a simply as you did. ThankYou for your reply... Brian
White954X4
10-06-2009 05:39 AM
