Dead key remote will not open the Security lock
Old Sep 28, 2021 | 11:37 AM
jannes_z-28's Avatar
jannes_z-28 is on a distinguished road
Default Dead key remote will not open the Security lock
Today one of the key remote died and doesn't open the door locks or open the security making the car not starting.
Since this is an export model it works with different frequencies so buying a new key on eBay isn't an option.
I need to disable this before the other key remote also die.
I have found some infor about this and cutting the cables at the ignition lock and connect them. There is a mention about a resistor that has a special value depending on the car.
I saw one video on YouTube were they just wired the cables together without resistor and did the relearning process. Will the relearning be necessary if I get the proper resistor?
Thanks
Old Sep 28, 2021 | 12:08 PM
GeorgeLG's Avatar
I don't know anything about differences in the security system for export models but a US 2002 blazer uses passlock which has no special key required so no resistor chip or transponder in the key. The process if your export model is the same is to cut the yellow passlock wire and expose a portion of the black or orange/blk ground wire and either measure the existing resistor value in the ignition module (black and yellow on the ignition side) and use that value or use a 2.2k ohm resistor because its a known good value. Then perform a relearn if necessary. This can be done under the dash at the steering column or at the PCM connector. The resistor goes from yellow on the PCM side to black and replaces the resistance presented by the hall effect sensor when the key tumbler is rotated properly at the column.
Let me know if you need more help.
George
Old Sep 28, 2021 | 12:14 PM
Thanks for the diagram. What I have understand it's only the frequency that the remote works on that is different due to some regulations by governments. Other than that it should be the same.
I'll give it a try.
Old Sep 28, 2021 | 12:28 PM
GeorgeLG's Avatar
There are more involved solutions involving relays but I think that is only for preserving a remote start function. If you just want the truck to start with the key in the ignition I think the simple resistor will work. Let me know how you do with this.
George
Old Sep 28, 2021 | 12:46 PM
I will manage with the cable trick as you describe. Only drawback is that the central door lock isn't working now with the dead key remote. Strange though red alarm button works but I guess that is another thing.
I have been thinking about to disable this security lock before any of the key remotes broke, now I'm there and have to do it
Old Sep 28, 2021 | 11:22 PM
Just a question about the resistor, If I just take a cable connected to ground up to the ignition loock and connect one end of the resistor to that ground cable and the other end to the now free yellow cable, that would work??
Old Sep 28, 2021 | 11:55 PM
GeorgeLG's Avatar
It may work but could be unreliable. The ground wire back to the PCM is a low ref/conditioned clean ground that keeps noise off of the circuit and the signal values stable and clean. I don't know how sensitive that circuit is
George
Old Oct 1, 2021 | 01:36 PM
GeorgeLG's Avatar
A couple of things if you are having problems with the resistor and relearn:
1) If a 2.2k resistor is not working, you can measure the existing value back towards the passlock ignition module and replace it with the exact resistor value for your ignition module
2) Even though its contrary to the whole point of a lo ref wire back to the PCM, some people have reported that adding a frame ground to that wire can solve problems
3) The relearn procedure:
George
Old Oct 1, 2021 | 02:17 PM
Thanks, I'll try that.
Let you know what happens.
Old Oct 1, 2021 | 03:14 PM
GeorgeLG's Avatar
Oh and check the TBC fuse.
George
