Defrost is blowing cold air
1997 S-10 Blazer 4dr 2wd LS . It recently had a new heater core put in,
heat worked great for a week or two then it went back to blowing out
cold air. So i replaced the t-stat and radiator cap then i flushed the lines
an im still getting cold air.
A NEW T-STAT WAS PUT IN THE SAME TIME THE HEATER CORE WAS CHANGED.
OH YA I ALMOST FORGOT . WHILE IN THE PASSENGER SEAT YOU CAN HEAR FLUID DRAINING ANY TIME YOU CHANGE MODE FROM DEFROST TO FLOOR OR ANY OTHER MODE . I KNOW ITS NOT LEAKING ,ITS LIKE YOU CAN HEAR IT DUMPING INTO THE HEATER CORE.ITS REALLY WEIRD. [align=right][/align][align=right][/align][align=right]
[/align]
[/align]
You have my attention, the caps are not nessessary.
The sound you hear in the heater core is probably air. If you have air in the system, you will not have sufficient heat.
I know that you said you had a new thermostat but I have installed faulty thermostats in the past on my own vehicles.
My blazer had the same problem, not blowing any heat. After flushing out the heater core, new thermostat and many people telling me it's the temp control sensor in the dash, found out my blend door actuator was stuck. One quick fix later and now all I have is heat(not a problem for now) but I need to replace it, online parts around $35. Dunno if this will help but it's another option to look at.
BlazaGuy95
24
Jan 26, 2014 05:58 PM
epederson
Dec 7, 2010 06:34 AM
Drivin_Foxfire
Nov 20, 2009 06:30 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
rdhack
Feb 9, 2008 10:32 PM
