Defrost not working after warmup
Old Nov 17, 2014 | 09:07 PM
blkgagt's Avatar
blkgagt is an unknown quantity at this point
Default Defrost not working after warmup
I have searched and can't seem to find this exact problem.
2000 blazer lt auto climate
On the first start of the day and if it's cold out I can control the selector to any place I want, floor defrost face. After the vehicle warms up I hear a air hiss and all the heat comes through the front vents. Even if the selector is at defrost or feet. What could this be? Thanks.
Old Nov 18, 2014 | 10:05 AM
LannyL81's Avatar
The hiss is from the selector switch leaking. Will likely need to replace the switch, but may be just a loose connection for when it gets warmed-up.
Pull the trim panel off and take a look at.
Good luck.
Old Nov 19, 2014 | 12:48 AM
blkgagt's Avatar
Good luck.
The selector switch? I have pulled out the hvac panel and looked it over. Nothing out of the ordinary.
Old Nov 21, 2014 | 07:19 AM
LannyL81's Avatar
Did you pull the HVAC panel and then run the engine until warm and check defrost operation?
Old Nov 22, 2014 | 01:48 PM
blkgagt's Avatar
No I haven't had a chance to do anything to it yet but want to this weekend. So unhook the hvac panel and run the vehicle? What am I looking for?
Old Nov 25, 2014 | 09:25 AM
blkgagt's Avatar
I made a video of it doing it this morning. Towards the end you can hear it switching from defrost to vent.
http://youtu.be/hTYYWr_gowA
Old Dec 1, 2014 | 11:07 PM
blkgagt's Avatar
Anyone help me with this?
Old Dec 5, 2014 | 01:44 PM
LannyL81's Avatar
Okay watched the video and have an understanding of the problem now.....air flow is switching from defrost to dash.
I always thought that defrost was the default safety position...so if vaccum was lost, air flow would be direct to defrost. So doubt this is a vacuum leak.
Wondering if the controller circuit is failing once it gets warmed-up and just switches air flow. Before replacing the HVAC head unit, I would crefully take it apart and check the solder connections for corrosion and reflow every solder joint on the circuit board. I have solved many problems doing this as all those temp cycles crack solder joints. Be sure to use a soldering iron, not a gun.
Let me know what you do.
Old Dec 5, 2014 | 11:43 PM
blkgagt's Avatar
The head unit? As in the switches (*****)? Or is there something behind that in the dash.
Old Dec 11, 2014 | 01:31 PM
blkgagt's Avatar
Well I got a different unit to see if that fixed it. It did not. So now what.
