diag code p0507
ok well i have searched this and also looked it up on alldata and cant seem to get this code fixed..
i got the light right after cleaning the throttle body and butterfly
since them i have pulled the iac cleaned it ** no fix**
replaced the iac ** no fix**
sprayed the whole moter with starting fluid looking for leaks ** no fix**
checked wiring
not sure were to go with this..
i have went though it all that all data says and didnt get anywhere
also forgot no out of normal rpms... runs like it shoul but crappy gas milage with this light on
checked wiring
Did you work through all the steps in this thread?
i forgot i did find a vacume like off the other day it came from the pass side and went down under the battery and i lost it.. it was off and laying on the dizzy cap.. so i looked and there was a valve right there on the firewall i pluged it into the bottom of that valve sice there was no vacume on there and i cane seem to find that ok the vac diagram i have
http://www.2carpros.com/forum/automo...0961_vac_1.jpg
sorry this is my drawing as u see in red the cavline on the pass side was laying there the one going to the driver side goes into the fender and then to the valve and this is where i put the vacume hose to
cluckerr
May 16, 2012 09:25 AM
krazii
Jul 27, 2011 12:51 PM
whiteman_01
Jul 14, 2010 10:28 AM
