Died pulling away after putting a few gallons in, now crank no start
Old May 16, 2026 | 01:52 AM
BlazerNovice92's Avatar
BlazerNovice92 is on a distinguished road
Default Died pulling away after putting a few gallons in, now crank no start
Anyone want a blazer? Bout to sell this roaming headache
Wouldn't start after initial death, started once and made it a block down the road and died again and just crank no start
Old May 16, 2026 | 12:29 PM
There is a good thread on diagnosing crank/no-starts.
Old May 17, 2026 | 09:15 AM
GeorgeLG's Avatar
Are you asking for diagnostic help?
George
Old May 17, 2026 | 09:52 AM
black04blazer's Avatar
black04blazer is on a distinguished road
I am going to guess that it is the fuel pump.
I have replaced my fuel pump twice, the first time the mechanic put in a no-name fuel pump against my wishes (I requested AC Delco/OEM GM) and it died in less than 10k miles (the original lasted more than 150k miles) and I wasn't fatiguing the replacement fuel pump with low fuel levels.
Napa auto told me that the Delphi fuel pump is the OEM fuel pump. I installed the Delphi fuel pump after the failure of the first replacement. So far it has been fine but it hasn't been that long.
Old May 17, 2026 | 09:56 AM
GeorgeLG's Avatar
If you want to go with the parts cannon, no problem I'll bow out. Let me know of I can help and your up for the process.
George
Old May 17, 2026 | 02:24 PM
George
Fires fine with a shot of starting fluid but dies right away so I'm going down the fuel issue route
Yesterday I popped the line off the outlet side of the fuel filter and confirmed good pressure back there
Going to check the key on and leak down pressure at the schrader valve in a little bit to narrow down the possibilities even further. Will report my findings
Old May 17, 2026 | 08:44 PM
Pressure at key-on was no more than 15 psi, so I'm most likely looking at a new pump huh
Old May 17, 2026 | 08:53 PM
Always do the fuel filter along with the fuel pump, if you need a fuel pump. Don't get a crappy pump--if you do, you'll be putting in another one very soon. OEM GM fuel pump is discontinued and some flavor of impossible to get. Napa auto claims that Delphi made the original fuel pump, and you can get a Delphi fuel pump for this vehicle, hopefully it is good enough! You can find a lot of ink spilled about fuel pumps for this vehicle, it apparently is rather picky.
And don't run your tank below a quarter gallon!
Old May 17, 2026 | 08:57 PM
GeorgeLG's Avatar
Your first test at the fuel filter confirmed that the pump is fine as long as you met the criteria in the fuel pressure testing sticky. The fact that it doesn’t hold it at the Schrader says it’s in the Plenum. The regulator or the injectors.
George
Old May 18, 2026 | 05:14 PM
George
Well to be honest i didn't actually hook anything up back at the filter just visually made the call that I thought it looked good enough. It actually did hold the little pressure it had at schrader for a good 10 min after key off...
