disabling daytime running lamps - '97 blazer
Old Nov 28, 2006 | 08:16 PM
magtec's Avatar
magtec is an unknown quantity at this point
Default disabling daytime running lamps - '97 blazer
i'd like to permanently disable the daytime running lamps on my '97 blazer (i turn the headlights on when driving, so the DRLs are only on when i don't want them to be). searched the forums, read a few posts, still not 100% certain about how to accomplish this. anyone care to clear things up for me?
Old Nov 28, 2006 | 08:59 PM
Chevy Lover's Avatar
Default RE: disabling daytime running lamps - '97 blazer
I would have a look in the under hood fuse panel for a DRL relay. Remove the DRL relay and check that everything else works ok.
Old Dec 1, 2006 | 04:28 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
On the 97's the fuse is in the fuse block next to the driver's side door (inside the truck)
Pull the fuse and you're good to go.
Old Dec 1, 2006 | 09:08 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Maybe you should follow this way:
http://www.geocities.com/zq8gmcsonoma/drl.html
I have done it and it have worked, Blazer '00
Marcin
Old Dec 1, 2006 | 09:26 PM
Jigg's Avatar
the '00 blazer is quite a bit different than the '97. All he needs to do is pull the fuse, on the '00 you have to pull the relay and bend back the tab.
Old Dec 2, 2006 | 01:37 AM
hillbillyinOhio's Avatar
yep, my 97 its fuse number 15, 20 amp. pull that fuse and DRL all gone!
chester92
Nov 14, 2011 02:50 AM
okstud
Jan 19, 2010 09:26 PM
drefda
Oct 5, 2006 01:32 PM
greengoose89
Jun 2, 2006 03:09 PM
RedBlaze
Sep 14, 2005 01:28 PM
