discouraged and cranky
Old Mar 7, 2018 | 06:25 AM
stoliautobody's Avatar
stoliautobody is on a distinguished road
Default discouraged and cranky
Hi I am new to this so here goes, I have a 96 4dr 4wd fully restored with 150,000 on it.I can crank the engine endlessly and it wont start but if I give it about 1/3 throttle it fires right up .I know fule injected vehicles shouldnt need to do that,any thoughts ?
Old Mar 7, 2018 | 09:00 AM
chevyriders's Avatar
I would start with a fuel pressure test, here is a great thread to guide you thru it.
https://blazerforum.com/forum/2nd-ge...eakdown-88305/
Old Mar 8, 2018 | 08:25 AM
jacked_72's Avatar
jacked_72 is on a distinguished road
Wild *** guess here, but you need air and fuel. Presuming that the computer is working right and the fuel pump is working right and the spider is working right, you might not be getting air into the intake. I know you said that your 96 has been fully restored, but is there a chance that the throttle body is all gummed up so that when you give it throttle, your're creating a path for air to enter the intake? Also are all your sensors plugged in, such as the MAF? How does it run once started? Will it idle?
Old Mar 9, 2018 | 04:48 PM
Thanks for the suggestions,I did a fuel pressure test and the pressure was fine but it didn't hold for long at all so I changed the fuel pressure regulator and now it runs like a champ,after 2 bad fuel pumps,[Car Quest brand] they upgraded me to a Delpi and paid the labor to put it in.I thought that was pretty good of them.Thanks again.
run_girl
Sep 26, 2012 04:50 PM
igs4dragon8
May 19, 2012 12:12 PM
JetJock79
Dec 31, 2011 01:11 PM
Ugly_Monkey
31
Jun 4, 2010 03:06 PM
baronthered
Oct 11, 2009 12:08 AM
