Which Distributor cap on 95 4wd?
Old May 23, 2009 | 11:11 AM
Indianarocker's Avatar
Indianarocker is an unknown quantity at this point
Question Which Distributor cap on 95 4wd?
Getting new plug wires shouldent be this hard. Anyone have a clue if this should be a top plug, or side plug distibutor cap on my 95 4wd? The wireset they say is for my model wont fit my cap. are these caps interchangable? Or maybe my motor has been replaced. I have a vortec v6 4.3. I have a side plug distibutor.
Old May 23, 2009 | 11:33 AM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
what cap did you have on there, 95's could have vertical or horizontal tower caps and both use different wires you have to make sure you purchase the corresponding wireset
DELPHI
XS10216 Spark Plug Wires, Set 30.570 24.456 0.000 1 1 95-95
[Spark Plug Wire Set]
90 Degree Boot at Dist ; Actual OE Part
XS10227 Spark Plug Wires, Set 37.100 29.680 0.000 1 1 95-95
Straight Boot at Dist ; Actual OE Part
Old May 23, 2009 | 11:36 AM
oisinirish's Avatar
Apparently it depends on the vin code for the engine.
Vin code W=side plug.
Vin Code Z= vertical plug.
Old May 23, 2009 | 03:20 PM
Look at the distributor. If your plug wires are coming out of the top of it, you have a top post distributor cap. If they are coming out the sides, you have a side post distributor cap.
Old May 24, 2009 | 08:03 AM
Thanks for the info guys
Old May 24, 2009 | 04:24 PM
Biohazed's Avatar
if its the same as my '95 its side plug.
mwillia
16
May 13, 2010 08:51 PM
panthersfan101
Engine & Internal
19
Apr 19, 2010 12:08 AM
matclark
Jul 3, 2008 08:04 AM
lcars
14
Dec 10, 2007 03:02 AM
blazerboy30
Nov 20, 2007 09:49 PM
