distributor ignition pickup
Old Dec 8, 2007 | 06:58 PM
rob2129us's Avatar
rob2129us is an unknown quantity at this point
Default distributor ignition pickup
what does the pickup igntion midule do? I have good fuel pressure and great spark. I was told by a mechanic that this module under the rotor in the distributor operates the injectors is this acuurate thanks Rob
Old Dec 8, 2007 | 07:26 PM
Default RE: distributor ignition pickup
The camshaft position sensor is located under the rotor in the distributor housing. The CMP sensor is used for spark and fuel injector timing on the '96+ trucks. For the '95 CPI motor, it is used for spark control. The reason I state this is because you did not specify the year of truck you have...
Old Dec 8, 2007 | 08:08 PM
rob2129us's Avatar
Hey Kyle thanks alot i really appreciate your help it is a 2000 blazer so that is most likely why my injectors seem to be not working. I really do appreciate the sharing of your knowledge Rob
Old Dec 9, 2007 | 02:56 AM
Chevy Lover's Avatar
Maybe a silly question but did you check the injector fuse?
What is your fuel pressure? "Good" pressure needs to be 55 to 60psi
I'm guessing that your engine won't start.
zippo305
Dec 20, 2010 11:22 PM
pak-man
Jun 3, 2010 06:26 PM
breakyadown89
Jul 27, 2009 11:08 AM
Driveby
Aug 8, 2007 12:14 AM
Jimmysls98
Feb 28, 2007 10:40 PM
