Distributor & Rotor build up causes misfire
Old Jan 30, 2011 | 06:15 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Distributor & Rotor build up causes misfire
I'm not certain of which brand is on the vehicle but here is the issue. The contacts inside the cap and the rotor itself are building up some carbon or something that is causing a misfire. (It is white.) I cleaned the build up off the cap and rotor not 2 months ago. I read on a post that I should only rely on A/C Delco parts. Any thoughts?
Old Jan 30, 2011 | 07:28 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
A/C Delco plugs only for these things. The whitish stuff you see is aluminum oxide and yes it'll cause misfires. It's easier for the spark to follow the buildup to the base of the distributor than jump to the tower where the metal is missing. If you haven't replaced the wires they're important too. Personally I've had good luck with NAPA ignition parts but buy the premium line. I dunno if it still holds true but used to be cheap line used aluminum posts, high end used brass.
Old Jan 30, 2011 | 09:01 PM
AJBert's Avatar
Regardless of brand, you want brass contacts, period. Yes, you'll spend more money for it but it will last so much longer.
Old Jan 31, 2011 | 07:29 PM
Chevy33's Avatar
Default Brass it is then
I think it was an aluminum contact I cleaned. I do prefer to purchase things from NAPA.
Old Jan 31, 2011 | 08:33 PM
blazinloud's Avatar
white and hard like the build up you get on battery terminals?
Old Aug 18, 2011 | 09:01 PM
Gremaldi's Avatar
Gremaldi is on a distinguished road
Somehow its true. A/C Delco parts, (distributor & distributor rotor) didn't have this problem. I mean, based on my experience on them.
Old Aug 18, 2011 | 09:35 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
I dont remember seeing brass inside my ac delco cap. It did feel heavier that the aftermarket i had replaced. I didnt look close but my gut tells me they may be steel.
Ive been wrong before, the only thing I can gauruntee is that i will be wrong again.
Old Aug 19, 2011 | 08:45 PM
RonJon's Avatar
You'll never see steel used as an electrical conductor. It has a high(er) resistance than copper or aluminum and can become magnetized. (BTW bronze is a copper alloy).
bigdaddykane93
Sep 19, 2017 10:36 AM
mwillia
16
May 13, 2010 08:51 PM
panthersfan101
Engine & Internal
19
Apr 19, 2010 12:08 AM
86Blazer4x4
Jul 16, 2009 02:36 PM
marksoftball
Jan 12, 2009 10:43 PM
