DIY How to secure your radiator drain cock.
Old Nov 23, 2019 | 03:13 PM
redhopper35's Avatar
redhopper35 is on a distinguished road
Default DIY How to secure your radiator drain ****.
On two different Blazers I've had the pin on the radiator drain **** fall out. Thereby preventing the drain **** from staying in the radiator. You can go spend about 7 bucks and get a new one, or just do what I did to repair it.
I simply put the drain **** in where it should be then drilled a tiny hole in it, right where the pin would be when locked in place. Then put a very small screw in the hole you just made, and you're all set. It will not pull or fall out without first loosening or removing the screw. I hope this helps someone. Thanks.
No false Bravada
Jul 10, 2015 07:28 PM
Hollywood411
Dec 5, 2013 02:12 PM
Swompdonkey
17
Mar 29, 2013 05:46 AM
Chadoo951
Feb 13, 2008 02:05 AM
2klt
Apr 4, 2006 11:48 PM
