Do Bosch platinum +2's spark plugs cause a misfire?
Old Aug 30, 2009 | 01:01 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Default Do Bosch platinum +2's spark plugs cause a misfire?
is it true that Bosch platinum +2's spark plugs can cause a misfire? i have a 1995 S 10 with a misfire under light accelartion between 1-2k RPM and not under heavy hard throttle. what are your experinces with these spark plugs? should i go back to the skock A/C Delco CR44ts plugs? thanks
Old Aug 30, 2009 | 01:04 PM
nervousmini's Avatar
nervousmini is on a distinguished road
Yup, ditch the Bosch plugs and get some AC Delcos back in there.
I have seen more ignition problems caused by using non OEM parts that it's usually not even worth doing any real troubleshooting until you get the aftermarket stuff out of there.
Old Aug 30, 2009 | 01:11 PM
should i put the exact AC delco plugs that are called for on the emissions sticker? or AC Delco rapidfires? thanks
Old Aug 30, 2009 | 01:16 PM
Either would be fine.
I am running the rapidfires, but only because the store only had 4 regular AC Delco plugs.
Old Aug 30, 2009 | 09:08 PM
number13man's Avatar
number13man is on a distinguished road
im sure you saw my post in the other thread but my bosch's (+2's) misfired as well. i put in the rapidfires, although the 41-932's were in before, and she ran perfect.
Old Aug 30, 2009 | 09:58 PM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
yep, bosch overall is a piece of ****.
Old Sep 6, 2009 | 01:41 AM
what about the new spark plug wires that i put? should i replace those too? i put brand new Jegs brand 8.5mm Super conductor plug wires on it. should i go back the the A/C delco spark plug wires? please let me know
thanks so much
Old Sep 6, 2009 | 02:22 AM
They are probably fine, no reason to replace them unless/until they go bad. The wires to avoid are the silly Nology/Jacobs style "booster" wires - once again trying to overengineer a simple part that already works just fine the way it is.
Old Sep 9, 2009 | 01:24 AM
rsturge's Avatar
rsturge is an unknown quantity at this point
i use E 3 diamond fire plugs with great results.
Old Sep 9, 2009 | 01:20 PM
sir otto's Avatar
sir otto is an unknown quantity at this point
I have always used delco plugs and wires. Well I am on my second set. i know they are a little more expensive and only come with a 1 year warranty but never the less overall quality is better.
