Door Hinge Pin Replacement
Good ideas, guys!
Since I've done it before on Mustangs and have to do it when it gets warm on both doors of my TBird and pass door of Bravadiva, I've been building a plan.
There is NO DOUBT hanging the door is far better and safer than rigging something to hold it up. But you need to do it in a driveway, so... HOW?!
Do what your great grandpa did.. build a tripod.
Some sort of anti-skid for foot of each leg. Door or car mats.. also could use the waffle type shlf liner for non-skid.
A ratcheting cargo strap. Everyones got some of those, right? If not, why not?
Either a strong hook from the apex bolt or wrap short end of strap over the peak and hook to strap.
-You'll want to wrap an old towel around the door frame before your wrap the strap.
Got the idea? In the spring, I'll try it out and write it up and take pix.
This is the best I can find of example.. dunno if it is a good idea to post it...
Like I said.. not sure of details but it will work.
Obviously one leg toward B pillar, other two outside of door.
Added in reference to Rotti, below:
Anyone who says TyRap zip ties wont work isnt using big enough zip ties. I would not try it with anything under a foot long; generally strength goes with length. IOW use handcuff types.
Compress Spring, pull all three tight as you can, cut off one of the tails, use other two as handles to locate the spring and hold in place.
- Now I'm building this in my head, so I'm not vouching that it wont have some problems but I am sure it can work -
Depending on your lift, three 2x4 .. 10 ft long. Drill a 3/4 hole a couple inches in from one end, each. At least 8 inches length 1/2" threaded rod or bolt and appropraite washers and nuts.Some sort of anti-skid for foot of each leg. Door or car mats.. also could use the waffle type shlf liner for non-skid.
Park it by a tree that has a limb you can use?! I removed them one by one before & by rocking the door you can get a hammer & drift & tap the pins out. As for the bushings & standard screwdriver & hammer will snap them in pieces, just be careful not to damage the bushings' seat in the hinge.
I also used plenty of anti-seize on them when I installed the new ones.
If you use the heavy duty zip tie method & can't figure out how to get the 3rd zip tie undone that'll be at the rear of the spring - get a thin, narrow piece of metal or old crappy screwdriver that will fit between the coils of the spring. Heat it up with a torch & slide it through the spring & touch the zip tie. That sucker will be under so much pressure it should pop off instantly!
the tool is well worth the money. i had my door balanced on a fllor jack with someone help hold it steady while i changed out pins & bushings. although it may be doable to replace one pin/bushing set at a time, i felt that the stress on the other one would be too much, wouldnt want to crack a brand new bushing set or bend a pin up. the most weird thing about the whole job was that the passenger door was worse than the drivers door as far as pin/bushing wear. back doors were fine and didnt need to be messed with.
billfrank85
May 11, 2012 06:33 PM
TouringMike
Sep 22, 2011 09:22 PM
conehead
May 22, 2009 07:16 PM
