Door jam switch wire location
Old Jul 10, 2005 | 01:31 AM
aspenpup's Avatar
aspenpup is an unknown quantity at this point
Default Door jam switch wire location
Ok, call me lazy but see if someone can help me out here.
I removed the ENTIRE dash on our '99 4-door Blazer to install ampifier (wire power direct to battery through firewall) and to also check the heater core for leak (smell in car). Anyway, took care of my issues and now putting everything back together but I can not find the wire connector that is supposed to connect to the right side (front) door jam switch.
I have looked all over the place and can not determine where this suckers cames from. I don't want to take the dash apart again (you try it!!!) and am hoping someone can give me an idea to avoid this. This is crazy that we can not find this. Any ideas?
Old Jul 10, 2005 | 09:06 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Door jam switch wire location
sorry,man. couldn't tell ya. i took my dash out of my 01 sonoma a year ago and im not looking forward to putting it back in after i paint my interior. well, at least ill know who to ask when i cant figure it out.
Old Aug 3, 2009 | 08:10 PM
kearney99's Avatar
kearney99 is an unknown quantity at this point
Can anyone answer this? I removed the dash in my 2000 Blazer to change the heater core and for the life of me I can not find the wire that goes to the passengers front door switch!
Old Aug 4, 2009 | 01:08 PM
kearney99's Avatar
Ok, So.. Apparently Chevy changed the wiring for the door switch in 2000, but didnt remove the switches from the dash.
There is NO wire. The switch just plugs a hole in the side of the dash. It serves no other purpose.
I stuck it in the hole with no wire on it after searching for at least an hour and just for kicks, closed all the doors. The dome lights worked as they are supposed to, even by opening and closing the passenger door.
I have no freakin idea why the would leave the switch in the dash if there's one in the door.
But....it works.
Guardian1014
Jul 11, 2012 03:31 PM
gatorboy44
Nov 28, 2011 11:55 AM
degaine_designs
Aug 30, 2010 02:06 AM
avfrff
Nov 16, 2007 07:23 AM
XBlazer01
Jul 6, 2007 07:51 PM
