Door Leaking...
Old Sep 22, 2009 | 08:22 PM
Sisk's Avatar
Originally Posted by oktain
SISK, where the stripping slips onto the pillar/roof could be where your leak is coming from. Id pull the strip down, and put a narrow bead of silicone along the edge of where the strip slips on, then put the strip back on and it should seal it inside. Hopefully that's your problem, I can't see water getting past the seal where it contacts the door unless you have a wire running over the slip, like for sat-radio.
Thanks Pat. The weather stripping actually had separated from the body right on the top of the A pillar where you talk about. I fixed that a while ago though with some silicone and glue, but it's still leaking. I have a feeling that's where it's still leaking from however since it seems to be running down the length of my A pillar and dripping in where the plastic comes up into a triangle on the other side of the mirror. Like I said though, it's not that bad...just a minor annoyance. One of those things I'll get fixed eventually..just like my damn door panels rattling lol.
Old Sep 22, 2009 | 08:52 PM
MachNU's Avatar
MachNU is on a distinguished road
This is a good idea, I thought about trying this. Would you mind taking a picture on your blazer showing the areas to put a silicone line on-to? Also would it be easier to just strip off the weather and door seal and reseal them on with silicone then on top of that add a new line at the edges once there back on?
Would rather try a $5 fix, before going at a $60-75 fix!
Old Sep 22, 2009 | 10:08 PM
old skool luvr's Avatar
Originally Posted by The_Beast
To add to your comment
The hinge pins are not that expensive they're about $6.50 per set. That's with all the parts you need, the pin, 2 bushings, and a locking ring. So you might as well just replace uppers and lowers
of course! (re changing the upper/lower at the same time). if the one pin/bushing assm is worn, then the other one is right behind it (from the added strain).
Old Sep 23, 2009 | 12:16 AM
jamesbalzer's Avatar
jamesbalzer is an unknown quantity at this point
Mine also has a mysterious leak except on the passenger side...already cost me a TCCM! New weatherstripping, new seals, even had a month old windshield replaced thinking it was that. Windshield guy is a friend and says he used two beads of silicone to seal this one. Freakin thing still leaks. Every time it rains, it fills the pass floorboard. Get this: if I park facing downhill it doesn't leak. Not sure how I figured that out, but put 80K on one of these and you learn some quirks. On the bright side, my Blazer pretty much just sits in the driveway and I never drive it anymore, so not a huge issue....until the next time I want to use the 4WD and the TCCM has corroded again!
Old Sep 23, 2009 | 07:10 AM
DriftinBlzr's Avatar
DriftinBlzr is on a distinguished road
My driver door was making a bunch of wind noise a while ago near the top front corner around the window frame. It would also leak like a sieve when I went through a car wash or heavy rain. I installed a new gasket and still had the wind noise and the water leak.
I fixed the leak after I watched an episode of "Trucks." They recommended the following:
1) Open the door.
2) Roll down the window.
3) Stand between the door and cab.
4) Place a knee against the door near the window opening.
5) Near where the leak is, hold the window frame.
6) Give a few quick tugs.
This bends the frame in toward the cab and helps give a better seal. I did this and been kicking myself ever since for buying a new door gasket.
Later, Doug
Old Sep 23, 2009 | 04:28 PM
that's your problem right there! not that you had a friend do it, but the fact that he used silicone. you only use Urethane when doing them (and i'm pretty sure it's law in Canada and the US).
Old Sep 23, 2009 | 04:30 PM
1) Open the door.
Later, Doug
have you looked @ your pins/bushings? 'cause my '98 did the same thing 'til i replaced them all (top & bottom, both sides). i actually didn't even have any bushing mat'l left on the top pin!
Old Sep 23, 2009 | 08:40 PM
I am sure he used whatever he supposed to. It LOOKED like black silicone. Hopefully that is what it should like???
Old Sep 23, 2009 | 11:27 PM
yeah, but a hell-of-alot stronger. if this is his profession (or he's like some of us, just always replacing some friend/family member's windshield), then he'd know what he's was doin'.
Old Sep 24, 2009 | 06:17 AM
The seal leaked way before the pins and bushings needed replaced. I've since done the pins and bushings and everything is still good.
Later, Doug
