Door Pins & bushing?
Old Jan 25, 2010 | 01:21 AM
flipstream's Avatar
flipstream is on a distinguished road
HELP - i went ahead and changed the pins/bushings as well, the door didn't sag anymore, but the previous owner bent the part that is connected to the body where the door latches onto, well actually pushed it into the body... am i gonna have to have a body shop fix that or is there something i can do?
Old Jan 25, 2010 | 07:11 AM
If it is pushed in, you are going to have to pull it back out into proper alignment with the door latch. This will include lining it up vertically as well (achieved by loosening the bolts).
I would try to line it up vertically first and see if it will work. If not, you may have to take it some place to have it fixed properly. It all depends on your experience and the tools you have on hand.
Old Jan 30, 2010 | 10:05 AM
flipstream's Avatar
anyone know the torx driver i need for the bolts on the door?
Old Jan 30, 2010 | 10:25 AM
samuknow's Avatar
samuknow is an unknown quantity at this point
Are the pins different for the upper and lower hinge? to do both doors i would need 4 total pins?
Old Jan 30, 2010 | 10:39 AM
Pins are the same.
Old Jan 30, 2010 | 11:50 AM
ABN31B's Avatar
Flipstream: which bolts on the door?
Old Jan 30, 2010 | 06:52 PM
flipstream's Avatar
I just got this fixed today... bought a set of torx bits from Harbor Freight and adjusted the height back by putting in some washers... now i just gotta change the pin & bushing on the passenger side.
Thanks for the tips!
Old Feb 2, 2010 | 06:06 PM
roycet4's Avatar
roycet4 is an unknown quantity at this point
Old Feb 4, 2010 | 03:14 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
So , no one got the part numbers for the HELP, NAPA or CarQuest Pins and Bushings?
Old Feb 4, 2010 | 05:08 PM
ABN31B's Avatar
do you need em?
if you do i can get them when i get home for you... or you could call NAPA between now and then. I still have the napa set in my garage somewhere.
